ENVIO FACTURA DE PRUEBA
Publicado: Vie Ene 18, 2013 4:39 pm
por APARISIOS
HOLA POR FAVOR ME PUEDEN AYUDAR CON EL SIGUIENTE PROBLEMA
Fecha de envio : 18 de enero de 2013 17:01:03
Nombre del archivo : C:\Compacw\Empresas\Belleza Integra\TSO991022PB6F0000000001.xml
Tipo de envio : De prueba (Integracion)
Mensaje del Servidor de Soriana : Error en Addenda de Remisión Reverse. The element 'Remision' in namespace 'http://tempuri.org/DSCargaRemisionProv.xsd' has invalid child element 'EmpaqueEnCajas' in namespace 'http://tempuri.org/DSCargaRemisionProv.xsd'. List of possible elements expected: 'Cita' in namespace 'http://tempuri.org/DSCargaRemisionProv.xsd'.
<?xml version="1.0" encoding="utf-8"?><AckErrorApplication xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" contentVersion="2.0" documentStructureVersion="AMC7.1" creationDate="20130118" documentStatus="REJECT"><ackErrorApplicationIdentification><entityType>305</entityType><uniqueCreatorIdentification>4004709</uniqueCreatorIdentification></ackErrorApplicationIdentification><ApplicationInformation><deliveryDatePresent>2013-01-18</deliveryDatePresent></ApplicationInformation><ReferenceNumber><referenceIdentification>99999</referenceIdentification></ReferenceNumber><Buyer><nameAndAddress><name>TIENDAS SORIANA, S.A. DE C.V.</name></nameAndAddress></Buyer><Seller><nameAndAddress><name>Belleza Integrada, SA de CV</name></nameAndAddress></Seller><messageError sequence="1"><errorCode>APLICATION ERROR CODE</errorCode><errorDescription><text>Error en Addenda de Remisión Reverse. The element 'Remision' in namespace 'http://tempuri.org/DSCargaRemisionProv.xsd' has invalid child element 'EmpaqueEnCajas' in namespace 'http://tempuri.org/DSCargaRemisionProv.xsd'. List of possible elements expected: 'Cita' in namespace 'http://tempuri.org/DSCargaRemisionProv. ... pplication>
Para soporte tecnico *del programa de envio* visita el foro http://www.validacfd.com/phpbb3
ESTE ES EL XML
(46.4 KiB) Descargado 251 veces
Re: ENVIO FACTURA DE PRUEBA
Publicado: Vie Ene 18, 2013 4:52 pm
Cuando necesites asesoria al respecto tambien sube como adjunto el XML para darle una revisada
Al parecer te falta llenar el campo de "CITA" pero no puedo confirmarlo porque no subiste tu XML
Publicado: Vie Ene 18, 2013 6:26 pm
OK, que diferencia, ya con el XML se puede ver mejor el problema
El problema es que tiene estos nodos en blanco, sin informacion :
<EmpaqueEnCajas/>
<EmpaqueEnTarimas/>
<CantidadCajasTarimas/>
Por lo que veo estas agregando la addenda usando Contpaq, comunicate a soporte tecnico de ellos para que te indiquen como llenar o de plano como eliminar esos datos.
