Error de consulta de operacion (COVE) con la version de demo
Libreria del Comprobante de Valor Electronico
tostinni
Mensaje por tostinni »
Hola
La semana pasada funcionaba correctamente la demo del COVE y desde ayer la consulta de operacion regresa un error:
Hubo un error en el envio : ns2.Server could not initialize a collecion: [mx.gob.ventanillaunica.www.cove.mode.RespuestaPeticion.coves#10663]; SQL [select coves0_.ID_OPERACION_COVE as ...
Al parecer podrias ser del SAT ya que con mis propias rutinas de envio al Web Service tambien me regresa un error 500 :(
error consulta cove.png (3.91 KiB) Visto 6879 veces
Re: Error de consulta de operacion (COVE) con la version de
Pues no me queda mas que confirmarte que si, esta fallando la consulta de operacion.
El mensaje de error completo que arroja es :
could not initialize a collection: [mx.gob.ventanillaunica.www.cove.model.RespuestaPeticion.coves#6398]; SQL [select coves0_.ID_OPERACION_COVE as ID20_848_1_, coves0_.ID_COVE as ID1_1_, coves0_.ID_COVE as ID1_936_0_, coves0_.BLN_IND_AUTOMOTRIZ as BLN2_936_0_, coves0_.BLN_CERTIFICADO_ORIGEN as BLN3_936_0_, coves0_.CORREO_ELECTRONICO_RESPUESTA as CORREO4_936_0_, coves0_.CURP_FIGURA_ADUANAL as CURP5_936_0_, coves0_.ID_E_DOCUMENT_COVE as ID6_936_0_, coves0_.IDE_EST_COVE as IDE7_936_0_, coves0_.FEC_EXPEDICION as FEC8_936_0_, coves0_.FEC_REGISTRO as FEC9_936_0_, coves0_.IDENTIFICACION as IDENTIF10_936_0_, coves0_.NUM_FACTURA_ORIGINAL as NUM11_936_0_, coves0_.NUM_EXPORTADOR_CONFIABLE as NUM12_936_0_, coves0_.OBSERVACIONES as OBSERVA13_936_0_, coves0_.BLN_RELACION_FACTURAS as BLN14_936_0_, coves0_.ID_OPERACION_COVE as ID20_936_0_, coves0_.RFC_CONSULTA as RFC15_936_0_, coves0_.RFC_REGISTRO as RFC16_936_0_, coves0_.BLN_SUBDIVISION as BLN17_936_0_, coves0_.IDE_TIPO_FIGURA_ADUANAL_COVE as IDE18_936_0_, coves0_.IDE_TIPO_IDENTIFICACION_COVE as IDE19_936_0_ from VUC_COVE coves0_ where coves0_.ID_OPERACION_COVE=?]; nested exception is org.hibernate.exception.SQLGrammarException: could not initialize a collection: [mx.gob.ventanillaunica.www.cove.model.RespuestaPeticion.coves#6398]</
Y esto es para el numero de operacion 6398, una operacion que ya habia sido aceptada hace mas de un mes
tostinni
Hable con el soporte de Ventanilla Unica y el entorno de pruebas esta en mantenimiento hasta el sabado 11/2 asi que espero que no tengan que hacer pruebas hasta ese dia. :(
Por otro lado. si es posible que usen el entorno de produccion ya que si no se usan los COVEs entonces no hay problema, luego se borran automaticamente.
Gracias por el aviso
Para comentar que hoy 16-feb ya esta funcionando la consulta de operaciones, no se desde cuando ya habia funcionado porque hasta ahora tuve la curiosidad de revisarlo
